Hi these are two separate queries,
First off,
What are the minimum requirements for someone to carry out an EICR. I thought it was this and that but basically someone told me that you dont really need anything, just competence which can be ascertained by basic things i.e. ecs card no?
I thought at least the appropriate qualifications and registration to a governing body such as nic or nappit?
Any clarfication would be appreciated.
Secondly,
If someone were to install a heat detector, could this be added to an existing circuit such as lighting or should it be run on its own dedicated circuit, I would assume a fire alarm system would need a dedicated circuit but presumably a smoke alarm or heat detector are less affected by the possible implications presented by using a non-dedicated circuit.
Regards
First off,
Secondly,
Regards
