Eicr,oh the joys of sparkies... | on ElectriciansForums
Discuss Eicr,oh the joys of sparkies... in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Doing an Eicr,just had 2,945 ohms on sockets,32 amp rcbo protects it,what code would you give it...Higher...Lower
Sounds like a TT system with a dodgy earthing terminal.
There are other likely culprits along the way. Earth loop testing through a RCBO?
I would first check the earthing system.
Earthing from a fortuitous routing or some pretty lousy conections or there really is no earth in the socket circuit or all of them.
Reply to Eicr,oh the joys of sparkies... in the UK Electrical Forum area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
