EICR on local swimming pool | Page 2 | on ElectriciansForums
Discuss EICR on local swimming pool in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Start with a risk assessment. Rather assuming this is a public pool and not a private one, as it's in use all the time....just wondering as you've questioned the type of earthing in use. Getting at least the lighting tested out of hours would be the best option (first thing in the morning before the pool opens, or negotiate a late opening for the morning of testing)....having the lights go out when someone's going off the high board wouldn't be good.
Only the room containing ths swimming pool is covered under the special location the rest of the building is just a standurd installation open to the public just not sure about the changing room areas
Reply to EICR on local swimming pool in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you are using Zdb you do not add on Ze as that is already incorporated into Zdb.
Pedantic Pirate Pounces Persistently! As my English teacher often said "Always avoid alliteration"
