T
Trickyd66
Hi All, new to the Forum so please go gentle!. Just been asked to provide estimate for some remedial works to an office from EICR to rectify code 2 defects as insurance company want completed. Apart from the old favourite of wood framed wylex boards (code 2, but IMO 3) (no mention of no RCD to sockets used by ordinary persons). Happy to change the db's to RCD/RCBO/MCB.
Main query is that the only other code 2 is -
"Consumer unit/ DB 4.7. Operation of main switch (function check) (613.13.2) Comment. The main isolators located within the mains intake position appear to be very dated. The integrity of the switch and its ability to function correctly can therefore not be guaranteed"
I always look that it that an EICR is a factual report on the electrical safety of the installation at the time of testing / inspection. Surely the inspector should have tested the operation and functionality of the said isolators at the time of testing and noted if they were actually faulty, not implied that because they are old require replacement under a code 2 deeming the installation unsatisfactory. IMO the good old Metalclad Wylex 60A SF will outlast anything I fit today!!
I would code 3 at best....... Any opinions out there?
Tricky
Tricky
