EICR - Unsatisfactory | on ElectriciansForums
Discuss EICR - Unsatisfactory in the UK Electrical Forum area at ElectriciansForums.net
Sunderland
Hi,
I am about to get an EICR done on a residential property. If a cooker isolation switch is less than 300mm from the hob will this produce an unsatisfactory.
Thanks.
Thanks Steve. The switch is to the left of the Hob as in the attached pic.
  • [ElectriciansForums.net] EICR - Unsatisfactory
C3 at worst (as potential to have flex draped across hot hob!), so no not unsatisfactory.
even then, a change of isolator to one with no socket would fix that.
p.s if you are paying less than ÂŁ100 for the inspection, he might not even look in the kitchen ;-)
probably won’t even get out his car
Are there any 32A/45A isolators that are "landscape" orientation in a 2G back box? Obviously there are loads that are "portrait" but the only ones I've seen that are landscape have a 13A socket with them. Fitting one of the standard ones on its side seems a bit, well, badger's.
Never seen one, but google unearthed this single pole Clipsal switch from Rexel in Australia. Maybe they were having the same problem and a manufacturer decided to plug the gap in that market...
First thought was a grid plate, but never seen a 45A grid switch either.
Reply to EICR - Unsatisfactory in the UK Electrical Forum area at ElectriciansForums.net
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
No it is not implying it is safe, it is stating what the recommended date for the next inspection is. The next inspection date sticker doesn't...
davesparks
