Discuss EICR What would you do? in the UK Electrical Forum area at ElectriciansForums.net
I'll start this again when I've worked out how to add a picture - any comments welcome!
Thanks BD. EICR = Electrical Installation Condition Report. Five bedroom bungalow, test out out of time, mixed MCBs and they're Proteus! - C2 or C3?
What is EICR ?
I would be more concerned about the three electric showers.
could someone enlighten me as to why a mixture of different MCB's should be coded at all? If they are marked as conforming to BS60898 and physically fit properly what difference does it make? It can't possibly be a code 2I would class the wrong MCBS as a code 2 - they not designed for the DB
it states in manufacturer's instructions to only use there breakers, bs7671 says you need to take manufacturer's instructions into accountcould someone enlighten me as to why a mixture of different MCB's should be coded at all? If they are marked as conforming to BS60898 and physically fit properly what difference does it make? It can't possibly be a code 2
Reply to EICR What would you do? in the UK Electrical Forum area at ElectriciansForums.net
