J
joehat
Sub mains to 2 x outbuildings.
Is the only way for this to pass an eicr is for the cables to be dug up and redone, I am going to make safe and add rcds by main fuse??
No armour or protection??
They looked like 16 mm t/e
I would put a c2 but if they wasn't gonna have it dug up Ect would you say an rcd would make it a lot safer and that's what I'm suggesting,
You cannot pass or fail an EICR, it is a report not an exam. You are giving a report on the condition of the installation in its current condition including an overall assessment of either satisfactory or unsatisfactory.
As for suggestions to rectify that problem: disconnecting it would be the cheapest soloution. Without inspecting that lot I can't really give an opinion on whether it is salvageable of not.
Thank you. I know it's satisfactory or unsatisfactory.
As you have no valid opinion apart from picking at my wordings, then I'd appreciate no more comments from you.
What's on the other end of these submains?
An office to one and an outbuilding/bedsit in another.
I would class it as unsatisfactory in a report but as the client will not want to disconnect, I would feel the best option is to recommend rcd protection at the points in then picture as a minimum. Obviously ideally I would recommend armoured cable or equivalent, but the cost i feel unless it's compulsory eg selling of a house then, It won't be a consideration to them.
As I previously stated you are there to do a report, if it's unsatisfactory with c2's and the customer ignores the report, there is nothing you can do.
Move on to the next job.....
wouldnt recommend a upfront rcd- if that meter cupboard is remote from the office and bedsit- then any nuisence tripping in those outbuildings would knock that rcd out and they would loose all power
To be honest I couldn't give two hoots what you appreciate.
If that black cable is NYYJ/hi tuff or similar then depending on installation method it may be salvageable. I doubt very much that the T&E is.
As I have already said, the cheapest soloution is disconnection of the whole rotten mess.
If you have us all of the information then maybe a more useful opinion could be put forward
Then issue the report and make your recommendations. Fitting RCDs will not provide the necessary protection for those cables, and you will then have carried out work which does not comply making you liable.
How about you get lost, I asked politely not to comment on my posts anymore, that's all my future posts
Joe and Dave please keep it civil to avoid the thread derailing, if you don't feel you can get on well enough to engage in the same threads may I suggest you use the ignore feature and at least that way the thread can stay open, cheers lads.
How about you get lost, I asked politely not to comment on my posts any more, that's all my future posts
A bit unnecessary if you ask me. Dave is a very experienced sparky and if you discount his input as not being valid, you will not learn from him.
Learning from others is what you need and nobody knows everything!
Surly as its my thread , if I ask for him not to comment further then that should be respected. I was not rude in. Asking him only when he ignored me just because he likes to be sarcastic ???
Maybe get someone who is experienced at carrying out EICRs to come and do a few with you, that way you will start to learn the process involved. You are there to report only, the install is not your problem. You're not there to do the customer any favours in terms of trying to achieve a 'Satisfactory' overall report. If something is wrong, which in this case it is. List it and code it in the EICR and then set out in your estimate for remedial works how you intend to rectify the issue and apportion a price to it. Simples. In this case I would get customer to contact a ground worker to lay some flexible 100mm ducting from A to B at a depth of not less than 700mm, make sure a draw rope is left in the duct, then you can quote for pulling in SWA (CSA determined via your cable calcs), terminating, testing etc etc. If they don't like the price then that's probably why it was bodged in the first place. Take your money for the EICR and walk away from the sorry situation. Don't become 2nd Lieutenant Bodge....
Also it may have been a good idea not to start stating who can and who cannot comment on your post. It is a forum after all, if you wanted specific answers to you query why not ask a couple of local sparks who you work with face to face, that would avoid all the nonsense stirred up on this thread?
Eicr
joehat,
Lazlo,
