I had 1st & 2nd fix on my extension done by a local sparks. It has taken about a month to get a cert from him even though he was paid in full, and even now it is dated incorrectly so I am waiting again now for a replacement.
I got 3 pieces of paper;- 1) Schedule of Test Results, 2) Electrical Installation Certificate, 3)Particulars of Signatories To The Electrical Installation Certificate.
The test cert is dated Dec 2007 which was the 1st fix, there is no other test certificate.
I did query this with him on Sat, he said that it was to test the circuits. I thought he did do another test at 2nd fix completion so surely I should have this to show the building inspector?
Is it normal not to provide a test certificate for the second fix? Incidentally some of the connections he had made to downlights had loose (arcing) connections, I also queried this and as I recall, he said that testing only shows up continuity and earthing, so what use is testing anyway?
