T
TPES
Ive got my pad and filling out certificate, At the very top it has a box for my registration number which i can easily fill in, but next to that it says certificate number?? empty box
What do i write in here?
I thought all certs had there own individual certificate number pre-printed on to each cert. as the NIC certs do.. why is my elecsa pad cert number box empty?
Hi Magic,
I`m with Elecsa as well, welcome to the club.
The number you need to put in is up to you, you give each cert a unique number.
I use my elecsa reg number *****
Cert number 01. 02 etc etc
and year 2009
I end up with *****-01-2009 and so on till year end then the last bit will change to 2010
Minor works i prefix MW before the cert number.
Cheers......Howard
Excellent, thanks for that, good idea.
I'll do that,
Would you also use this as "your job reference" number when sending jobs to be notified? or do you leave this box blank.. ( its one of the options on the online form when notifying a job, step 5 i think)
Elecsa Certs... Cert Number??
Business Related
TPES,
SirKit Breaker,
