elecsa | on ElectriciansForums
Discuss elecsa in the Business Related area at ElectriciansForums.net
Norwich
i've managed to secure a job in order to book my Part P assessment, i would like to go with elecsa. the job is putting in a new ring main and a new lighting circuit and a smoke detector in a new extension on a bungalow, it consists of 2 bedrooms and a hallway. does any one have any idea s to whether this would be sufficient enough to fullfil their requirements?
Hi im sure that will be fine, just had mine this morning, i installed a new ring and cooker circuit only. He didnt really look at it , just made sure i knew what i was doing with the testing really.[Edit i forgot i changed the Consumer unit also]
Good luck,
vambo
Hi, I joined ELECSA in March, I was told that I needed two jobs and one had to be a CU change, the inspector wasn`t really interested in how I had done it, just that I knew what I was doing on testing.
Make sure you read up on the regs though, also job had to be within 15 minutes of the appointment address as it took 3 hours to go through paper work and questions before we went to the job. Hope this helps.
As a minimum they'll want to see a "major" job, i.e a CU change and a "minor" job, i.e an extension to an existing circuit.
They want to see a job that is a fair representation of the type of work you carry out. So if you register a few rewires then dont take him to see a couple of outside lights that you have put up. To answer your question, yes the job you are proposing to show him will be adequate. Make sure all the notices are fixed to the CU, like mixed wiring, RCD, etc etc..
Cheers.........Howard
Reply to elecsa in the Business Related area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Concerning isn't it. I fear it's just going to lead to reduction in standards and entry requirements and flood the industry with even more poor...
