Electic Shower | on ElectriciansForums
Discuss Electic Shower in the Australia area at ElectriciansForums.net
C
cclifford
Installed a new shower and have the power light on the shower lit but when i switch it on i lose power.:mad:
Check your connections at shower and isolator. It's possibly a bad connection or a cable not stripped back properly and tightened down onto the insulation. Have you tested the circuit R1 + R2 etc?
If RCD/MCB is ok water pressure is ok connections ok only thing really to do is get an electrician in to test properly it may be that the fault with the old shower wasnt a fault at all but you may have problems elsewhere that is causing both showers to misbehave.
Chris
Reply to Electic Shower in the Australia area at ElectriciansForums.net
I
No water in shower head, pressure/flow problem Dear Professionals, could you please advise. I have standard mixer tap in my bath (its about 15...
IrinaPri
I
I
Not much water from shower head but high pressure in tap Dear Professionals, could you please advise. I have standard mixer tap in my bath (its...
IrinaPri
I
