New build domestic which uses external window blinds. Each blind is supplied with L N permanent then switched L for up and another switched L for down. Blinds self limit at extremes. (Thus 4 live conductors). There are 15 blinds, all running back to central "smart home" gear/relays where they can be independently switched.
537.2.1 "Where electrically powered equipment is within scope of BS EN60204, the requirements for switching off for mechanical maintenance of that standard apply".
Same applies to 537.4.1 re emergency switching..
..So does it or doesn't it? (scope BS EN 60204)?
One would fit local 3 pole conventionally to (somewhat less dangerous IMO) extractor fan motors.. so thinking along those lines leads me to believe I may need local isolator for each blind (4 pole).
One remote, (alongside the CU) isolator for the whole lot I can cope with.
But I can't cope with fifteen local 4 pole isolators. - And BS EN 60204 costs about ÂŁ300.
What's the thoughts here?
