Electric boiler installation | on ElectriciansForums
Discuss Electric boiler installation in the DIY Electrical Advice area at ElectriciansForums.net
UK
Hi,
I am installing a 12kw instantaneous water heater in an outbuilding which currently has a small water boiler with electricity and water in/out already connected so I thought it should just be an easy switch over.
The new boiler has arrived and has a much thicker cable (10mm2) and I was wondering if I could still use the same switch to install this?
TL;DR
Can I use the new thick electric cable with the same switch?
  • [ElectriciansForums.net] Electric boiler installation
@James Sorry a follow up question, would an electrician be able to connect to a closeby closed socket (live cables from mains behind), or would it need to be wired back to the main board?
You cannot wire a 12kw boiler to a 13A socket! See post #2. I would recommend getting an electrician involved.
It is impossible to tell.
you really need a visit from an electrician to quote this job.
Reply to Electric boiler installation in the DIY Electrical Advice area at ElectriciansForums.net
Issues With Nest Generation 3 Operating Boiler? I have a Google Nest Generation 3 Thermostat/Heatlink, Thermostat is in the hallway and operates...
Dulbert
Electric combi boilers are not as effevtive to heat flowing water compared to gas. I'd only consider an electric combi if you lived in the middle...
