electric boiler | on ElectriciansForums
Discuss electric boiler in the Central Heating Systems area at ElectriciansForums.net
nw london (Stanmore)
just been out to price a job, basically it a large 1 bed 1 bath bathroom penthouse type flat with a 23kw output gas combi boiler, for reasons apparent to only others they are unable to replace the current knackered boiler with a gas one, so call in your friendly sparks, any ideas on what could be used, tenant would prefer not to have a large cylinder sitting in the cupboard as that is where the washing machine currently site, Cheers
Looked into electric boilers about 12 months ago when a customer was looking to avoid installing a gas supply to a couple of properties I just couldn't make the figures stand up they are just way to expensive to run when you look at the cost of doing the same with gas
For that size any new combi will work up two five rads and if the water psi is good 24+ your bathroom couldnt be more than 10m away.I would go for a green star 24s bosh my self up to 7 years warranted cheapest to run and fit but around 750 to buy plus fittings
Exactly!! :sailor:
Have you tried to fill a bath in a reasonable time in the middle of winter with a 24kW boiler ????
Trust me ...... you NEED a 28kW !!!
(You can always turn the hot water stat down in the summer ;) )
Reply to electric boiler in the Central Heating Systems area at ElectriciansForums.net
Electric combi boilers are not as effevtive to heat flowing water compared to gas. I'd only consider an electric combi if you lived in the middle...
T
New plumbing & heating system advice Hello, I'm installing a new central heating & plumbing system and just wanted to run through my design...
Tommyh311
T
