Hello,
I would begrateful for some advice.
I have recently moved into a property which has two detached outbuildings, one used as a garage and the other as a workshop, no heavy machinery just the run of the mill drills and saw.
The outbuildings are connected to the house in this manner;
From main ConsumerUnit, 80A / 30mA RCD via a 32A MCB to the Garage Consumer Unit,63A / 30mA RCDvia a 32A MCB to the Workshop Consumer Unit, 40A / 30mA RCD. The circuit is earthed via an earth rod ouside the house.
What I would like to know is does this meet the existing requirements or is it an overkill?
I am not after technical details as I intend to contact a local electrician. What I will be grateful for is some information, if this set up does not meet standards, so that I can have an idea for when I get the quotes.
Kindregards
Kindregards
