electric cooker tripping | on ElectriciansForums
Discuss electric cooker tripping in the Australia area at ElectriciansForums.net
B
BD10NER
hi guys
Can anyone advise what maybe the cause of electric cooker tripping out when switched on, the cooker was in a flat
in old folks premises and taken out and put in another flat of the same block, basically taken out and put back in
all the rings work fine but when oven switched on it trips out ??????????
not straight away after it heats up a bit.
Element IMO. Are you able (competent) to check it out yourself? You might try the U K Whitegoods forum for some assistance etc as they also have a spares section I think (or espares etc). An appliance engineer might cost a fair bit but an easy job if you can do it yourself.
Reply to electric cooker tripping in the Australia area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
