Am I right that 230v 7kw requires a 4mm2 cable from the cooker to the connection unit?
thanks dark wood I'm going to ask for it then for referencing cheers for adviceOK - it just helps when giving advise that the mentors know if you have the regs or not, I would put it on your xmas list if you can, its invaluable for referencing graphs, tables charts etc and makes explaining any queries you have a lot better if we can guide you to the relevent regulation![]()
Cheers electrix I have just borrowed John Whitfield 2011 edition off someone will that be ok?lee. i'm sure a member of this forum will be able to let you have a green 2011 version for next to nowt. it's only a few trhings altered in amd.3. and will help you a lot.
Drop me a pm mateCheers electrix I have just borrowed John Whitfield 2011 edition off someone will that be ok?
