Electric cyclinder programmer - advice needed | on ElectriciansForums
Discuss Electric cyclinder programmer - advice needed in the Central Heating Systems area at ElectriciansForums.net
cowboy
England
Hi all,
unvented electric 3kw cylinder to be fitted to property alongside electric water heater for radiators. The water heater has terminals for supply and control wiring, the cylinder does not.
I was hoping to use original half of standard 2 channel programmer for the water cylinder timing.
Is there a relay available to do this job controlled via existing wiring centre or would I be better finding a separate timer suitable for the 6kw load?
thanks in advance
Cheers for the input pal, my thoughts exactly but customer wanting more accessible control, ideally from the existing two channel programmer . . does such a thing exist that can be installed easily?
Reply to Electric cyclinder programmer - advice needed in the Central Heating Systems area at ElectriciansForums.net
My guess is that you'll need to have your existing re-jigged as you've probably got a separate consumer unit fed from the time clock side of your...
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
