electric doors only open 1 way | on ElectriciansForums
Discuss electric doors only open 1 way in the UK Electrical Forum area at ElectriciansForums.net
stodsy
hi iam a electrician and have come a cross a job thats new to me its on a set of doors that open as you come in front of the sencer but the problem is on the way in they do not open can any 1 who as work on these door help please and say what i should be looking for thanks alan
faulty sensor, broken connection, you need to open things up and have a look. try swapping the external and internal sensors, see it the fault goes to the inside.
so if i strip down the sencer that works and look at how it is connected up then check the faulty 1 to see any cable damage if not sencer is broken how much are these sencers and thanks
Is there not a selector switch on the doors somewhere??
Sometimes it's a simple rocker switch on the door unit itself, sometimes a stand alone key switch located above or to the side of the door etc.
hi lenny its all new to me sorry pal so if i go to the swicth am i looking for a break in the cable or a faulty swicth getting out of the block is fine but getting in you have got to pull it with your hands thanks alan
Reply to electric doors only open 1 way in the UK Electrical Forum area at ElectriciansForums.net
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
