Electric fences | on ElectriciansForums
Guest viewing is limited
Discuss Electric fences in the UK Electrical Forum area at ElectriciansForums.net
U
underpar12
Had a call today from a golf club, wanting me to investigate a drop in voltage on there fences around the greens ,the fences are feed from a time clock back at the club house. I have not visited as of yet but could do with some useful info when I get there.
My guess is that one or more of the fences is coming into contact with the "ground" which reduces their effectiveness massively.
I would recommend you visit when they are switched on and walk alongside them in silence and listen for "grounding".
Do the club have a "tester" that shows the effectiveness of the fence? This could help too.
Walk the entire length of the fence to check for shorts to ground, anything down to a single blade of grass touching the fence will drag it down.
Check the the earth rod and it's connections are in good condition, check the Ra of the earth rod.
Get hold of an electric fence tester before go there so you can actually see what's going on, it will register the voltage of each pulse from the controller. Pulses should be somewhere between 5 and 10 KV
My experience is with chickens - whats yours Andy?
If they are tapes , have a look at the inlaid wire strands to see if they are getting worn and broken , this is also applicable for the plastic wire version which is inlaid with thin wire strands as well .
A decent fence tester is a must to find the variations down the line .
I have seen it done with a blade of grass , with the change in the "crack" signifying the trouble spots , but the old boy doing it was a proper old timer farm hand .
Generally what ever Davesparks said , is spot on
Reply to Electric fences in the UK Electrical Forum area at ElectriciansForums.net
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
Thanks for this reply, this has helped!! I felt quite deflated and let down by this experience (1 bad thing wont end my hopes of being a full time...
Recommended Sponsor News
Hi everyone,
