Evening all
I have a fly light to repair from my mates shop that i'm having a bit of bother with, thought id post it up in here and see if i can learn something!
Its a 2 x 36watt Genus spectra fly light, the light was reported as not working one day, no idea if one tube went off first or if it just stopped altogether. I pulled the fuse from the switch fuse spur and checked it.... it was fine so i put it back in and switched the spur back on, both tubes tried to light then flickered and went off. I turned the power back off then on again with the same result. I took it down and brought it home to have a play with.
Upon opening it up there is basically just an electronic ballast and two 36watt tubes, i assumed since the tubes were almost flickering into life they were probably ok? i took the ballast into my local wholesaler and they sorted a new tridonic one out for me which is the same pin configuration but slightly different size, anyway put the new ballast in and it was exactly the same so its probably the tubes, before i start ordering tubes i'd like to know how to test the outputs from the ballast and also if you can test the tubes with a meter or not?
Any advice appreciated as im interested in learning more about how they work and how to fault find not just looking for someone to fix it for me if you know what i mean!
Thanks!
Stu
Thanks!
Stu
