Evening Ladies and Gents,
Just after some advice on some electric heaters as i am used to using gas. Customer wants to install 3 1000w panel heaters and 1 750w towel rail. Any fixed aplliance over 2kw must be on its own circuit. If they are put on two seprate radials with with two heaters on each, would that be best practice. Secondly he wants to install an instanteous undersink heater which is 3kw. That to would be on its designated circuit.
That is what i thought you would say and i totally understand. The clients wish list includes Electric shower,single oven,induction hob,immersion heater,4 heaters,2 rings, lights and a smoke. Would you recommend putting the heaters on a seperate board
I would be putting the heating and immersion heater on a separate board and eact cct radial to one point, and advising the client to look at some of the economy tarrifs available.
South East Kent
electric heaters
Australia
Rockomuir,
Wiredspark,
