hi all,
been to a job today where the kitchen fitter has fitted a new 6.8kw hob next to a tall double oven unit.
there is about 15mm between the edge of the hob and the side carcass of the cupboard.
what is the minimum distance you can put a hob from one of these cupboards :confused::confused:
Not sure about the sides but i think the back is around 50mm???
Should say in the installation manual.
hi jason,
the back will is a plastered wall so no problem there.
the side though is a full height laminated chipboard carcass that would burn well :eek:
Basildon, Essex
Website
http://www.aptelectrical-co.uk
Electric hob
flukey,
flukey,
