Electric Hob | on ElectriciansForums
Discuss Electric Hob in the Australia area at ElectriciansForums.net
A
acat
Hi All
Been asked by a customer who is almost blind to adapt a cooker hob. It already has a small red light to show it is on but this is now to small for him to see. Best compromise I can think of is a separate light on the wall run from the existing light.
Has anyone come across this before and/or have a better suggestion.
Chris
Hi All
Chris
Why not give the RNIB a call & ask if they have come across any products.
RNIB - supporting blind and partially sighted people
Thanks for the above Sparks72 just come of the phone to them. They advise a plastic template below hob controls similar to braille. Or if ordering a new hob it can be customised at source. Just for info incase anyone else comes up against this one.
Chris
Reply to Electric Hob in the Australia area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
