I got called to have a look at a socket an old customer is having trouble with tonight
Basically they have had 4 new kettles in 3 months and all have packed up, these are not cheap makes they are spending £50 + each time and have returned them all and tried different models ,
Eventually they thought maybe it's a power issue and called me,
So I went to check the circuit, which tests as normal nothing to raise an eyebrow at all..........
I replaced the socket anyway just as a precaution although nothing seems wrong with it.
I tested the voltage for over an hour just to see if there was anything unusual happening and again nothing out of the ordinary.
The only thing I noticed was that the kettle they had was rated for 220v to 240v whereas local voltage was 245v which I can't see would be an issue surely???
Seeing as the UK is largely still 240V+\- a few volts,
I have suggested if it carries on that they can request their supply is monitored to check if there are large fluctuations
Anyone had similar issues ????
