Electric shower fitted on the wrong end of bath.
It’s C1, C2, C3 for things actually checked and be coded.
FI for Further Investigation
NV for not verified. Means it’s there, but I couldn’t physically test it / couldn’t be bothered.
NA no applicable. It’s not there to be tested.
Everyday is a school day. Thanks for your replies really appreciate it. Common sense tells me not to fit a shower that end, I must be the only one. I still wouldn't fit a shower that end. You would have to point the shower 90 degrees off the wall to wash your hair, unless your bald then its ok lol
FWIW, the last electric shower I fitted was to a double-ended bath where the taps were in the middle, so I had a choice of 2 walls to fit the shower to...but in the end, I fitted an instant electric shower to one end and another one, off the combi boiler, to the other end.
I couldn't fit any shower above the taps because there wasn't a wall there, just a window.
The numpties haven't fitted the shower in one of the zones have they? Then yes, it's a C2. Everyone knows water and leccy don't mix. Shower should be at least 600mm away from the end of the bath or preferably on the landing.
Absolutely not. The cubicle is to keep the water off the electrical equipment. Would you suggest fitting a shower head in a switchroom? I think not. Musical Differential Inflammation or whatever it's called.
BTW I can't believe you gave me a thumbs-down for post 24... you've upped my neg rep by 20% in one hit!
I think your reputation will survive this little dent!!
Kellogs64,
James,
