Electric shower temperature fluctuating | on ElectriciansForums
Discuss Electric shower temperature fluctuating in the UK Electrical Forum area at ElectriciansForums.net
Subby
Wales
Hi all plumber here...
My customer complained about fluctuating temperature at the electric shower so I removed the said shower and replaced with a new one.
They still have the problem, and a neighbour has suggested it may be "something to do with the fuse box"
Is it possible that this could be an electrical fault somewhere?
The rcd is fourth from the left (next to the one labelled rcd circuits) the shower is 9.5kw. Nothing trips out.
Thanks in advance.
I tried to upload a picture of inside the consumer unit, the live wire to the shower looks to be about 8 mm diameter and the shower is about 4 metres away from the rcd.
Here is the picture. The shower is the fourth from the left
[ElectriciansForums.net] Electric shower temperature fluctuating
If it’s an intelligent shower it may be water pressure making the safety come on and off. I had one the other day that would go cold and show LP (low pressure) at 0.7 bar. We got in touch with the water supplier to check mains pressure in. Not concluded yet but also haven’t heard anything.
A fluctuating temperature either means the temperature of the incoming water is varying a lot, which is only likely if the cold pipes are run in contact with hot pipes, an under pressure cut out, but only if the shower changes in flow as well as temperature, or that there is an intermittent loss of power to the elements, this is usually caused by an overheating connection. Most commonly this occurs in the shower isolator switch, but may also occur in the consumer unit, not on the line as shown in your picture, but possibly the neutral.
Can't imagine the incoming water temperature to be varying wildly enough to cause this.
As Richard says above, could be poor connection somewhere. Check all connections are made correctly and are tight enough - from the MCB, through the isolator and at the shower. Maybe an old isolator switch which has gone a bit 'high resistance' at its contacts?
Another thought - do they see slight varations in brightness of lights in the house? Could be supply issue?
Bristol water only allow for 1 bar pressure at the incoming meter. That’s not a lot of pressure and when the street on that main are on and off with their demand it could be giving an up and down slight of pressure. Just realised you’re a plumber and you know that! Sorry wet pants!
Have you checked water pressure in? out of interest.
Are you able to replicate the fault? You may then be able to see if the preasure is dropping or the power cutting out. Is there a light or indicator on the shower to show it has power? This may flicker or go off if there is a fault with the supply.
As others have said, check all connections to make sure they are tight, and look for signs of heating or arcing at the terminals. It may be better to get an electrican to do this part.
Reply to Electric shower temperature fluctuating in the UK Electrical Forum area at ElectriciansForums.net
