Hi
I've seen a thread on here (which is what brought me to this forum) where someone had an issue much like my daughter has. The shower works fine for a few minutes, but if she's washing her hair and takes a little longer than usual, the shower trips the MCB.
Is there an electrician on here from Swansea who would be able to check whether the MCB is faulty, or determine the cause? Or maybe you can recommend an electrician who's helped you in the area.
Thank you
Bernhard
Thank you
Bernhard
