E
ezzzekiel
more a plumbing question, and ive tried a couple of plumbing forums but no response so,
fitted a new elec shower, no probs, could not use existing water feed from cold so had to come from above in loft.
elson heating tank with small cold water header tank fed by 15mm rising main. cut into this pipe to feed shower and everything fine except whenever they use shower the overflow pipe throws water over the back door
thinking that the when shower on water is forced through the pipe above the ballcock and so maybe just needs ball adjusting or replacing.
any one any other ideas on the matter?
(plumbing not my strong point ad i usually dont bother unless its straightforward)
