Electric Shower | on ElectriciansForums
Discuss Electric Shower in the Australia area at ElectriciansForums.net
The best shower is the next door neighbours
No install and set up fees
Its cheap on your electric bill
It doesn't impact on your water costs
Maintenance free
Usually free replacement when faulty
Never causes leaks through your kitchen ceiling
Cleaning carried out by others
If you cant be tempted by that,try the MX inspiration range
I have fitted quite a few and they are reasonably priced and have never been a problem
Maintenance free
Like it mate
I actually wanted to start a new post, but could not find how on this forum.
anyway, I have a broken Triton Opal.
I know I can change with either another Opal, or a Martinique. Both do not need me to replace the connections:
- right side electrical cables connetion
- bottom right side piping connection
But looking at other brands, which models can I buy to replace my Opal, with same connections ?
Thank you
Shivy
Reply to Electric Shower in the Australia area at ElectriciansForums.net
L
PIR sensors in a shower room Electrical Advice PIR sensors in a shower room Discussion ThreadPIR sensors in a shower room Electrical Advice Can...
L
J
Electrician Electrical shower problems Electrical shower problems I have installed a new shower and when the dial is turned to economy the light...
Johnales
J
