C
colour
Hi could you please advise. we would like to replace our electric shower. it runs off one cold water feed. at the moment it is 7.5w and its connected to a shower pull switch, and then runs direct to the fuse board by means of a 6mm cable, some one has said anything above 7.5w should be run on a 10mm cable. what is the maximun electric shower we can run on this 6mm cable without overloading it .there seems to be more choice for 8.5w and 9.5w but not many 7.5w. thanks.
