Electric Shower | on ElectriciansForums
Discuss Electric Shower in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Hi All
I've got a strange one, I've just replaced an electric shower because when you turn the shower on, the neon indicator at the switch goes off, and obviously the shower doesn't work, however, like I said I've replaced the shower but the fault remains, any ideas.
Also there seems to be supply on the neutral from the switch to the shower (only when the switch is on), is it likely to be the switch at fault, the cu seems to be wired ok but it's the old rewirable fuses and no rcd.
I'm going back Friday to replace the switch, but it's all trial and error at the moment.
Cheers Julie
sounds like the switch or a bad connection . as soon as you try and pull a load, it fails. and you should consider a CU upgrade to include RCDs.
Thanks for that, it's more or less what I thought, I've suggested a new cu but they don't want to pay for it, so I'm gonna try and talk them into a small one just for the shower.
Wish me luck
Jools
i would insist on a RCD if only for the shower. as you are doing a like for like replacement, then it's not essential fo you to fit a RCD, but you'll sleep better if you do.
I know this is with the benefit of hindsight BUT most shower companies mention RCD's in their instructions so add it to the quote for the new shower so they see this before you start.
Hi All
Cheers Julie
Shame you didn't, test the circuit of the existing shower before talking them into a new one, at their expense I would say lessened learned.
Reading it again I nearly fell over, not only did you replace a shower which may not be faulty, but you couldn't get the new one working left site and will go back Friday, please take some test kit and common sense with you when you return so the Bill is not so high the Customer has a panic attack.
Hi All
Cheers Julie
Sounds like the switch to me! I hope you're not charging for the new shower as that wasn't the fault and even a simple voltage tester would have showed that!
Reply to Electric Shower in the UK Electrical Forum area at ElectriciansForums.net
Oh definitely, the amount of tails that I come across in consumer units barely nipped up is staggering, I always tighten them, wait a minute, give...
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
