A
action jackson
I will be installing Warmup electric UFH in my bathroom today and would appreciate some guidance with running the heating element power cable to the thermostat.
I had planned to run the power cable within the 150mm vertical "safe zone" of a stud wall to the thermostat which will be located on the other side of the stud wall.
However reading through the instalation instructions it states the power cable should be protected by plastic conduit or trunking. Is this still valid if i run the cable within the stud wall? Note the circuit is protected by a 30ma RCBO.
