Hi,
My drivers side electric window motor (and electric mirror adjuster) no longer works - I am told water got into it so it is not repairable. As it is a rare model (6Q1 959 801C) for which no replacements are available, I purchased an alternative 6L1 959 801 motor and fitted it. Unfortunately it has totally different electrical connections. Does anyone know which pins on the new motor I should be wiring from the which pins in the old one? The original motor also controller the passenger window, but I don't mind if that function is lost, I would just like to wire up the drivers side window (and, if possible, the electric mirror - but that is less important, since If I can open the window I can always adjust it manually)..
