Electrical cable Overheating | on ElectriciansForums
Discuss Electrical cable Overheating in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Roshan
Sri Lanka
I hava a 185sqmm SWA/XLPE underground cable supplying 240kW(Peak) at 400v. Ambient temp. around 28 c .
  • What is considered the upper temperature limit the cable can heat upto?
  • What is the standard (theoretical calculation) available to get the overheating limit?
Hi - you can ask manufacturer to confirm, but max conductor temperature of 90 C may be possible, depending on the installation terminations also being rated to that temperature. Otherwise I use 70 C.
Is 28 C the ambient temperature of the air or the ground?
How much current are you pulling through that cable out of interest?
As already said, 90C for Thermosetting cable but terminations will likely only be rated for 70C. Where your terminations are will be subject to different rating factors though. E.g. you could have cable in buried ductwork in excess of 70C and termination points above ground at less than 70C which would be fine. Also, how deep is it buried and is it grouped with any other cables?
Sounds like a college question - not sure if he’d ask on a forum relating to a 185mm, that’s a big booger.
Reply to Electrical cable Overheating in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
