Electrical ceiling rose move ahead of plasterer? | on ElectriciansForums
Discuss Electrical ceiling rose move ahead of plasterer? in the UK Electrical Forum area at ElectriciansForums.net
Dim spark
Preston
Hi all,
Have a plasterer coming overboard and skim a ceiling and I gather it is not good form to board around a rose, so ...
Would it be best to unscrew the rose and just knock through to the loft and push it through and board over the lot?
Then I can just reposition the wiring afterwards. (It needs centering anyway in the room.)
There is not enough slack in the cables (three twin & earth) to pull them.down and through into the room.
Thanks.
If it’s got an attic above, then perfect to remove rose, put all into a joint box above the ceiling, then run a new cable from jb to new light position when plasterings done.
Obviously I can’t comment on your capabilities, but remember to turn the power off. 3 t&e suggests a looped live, So from assumptions- the 3 reds in the centre will be live even if switch is off.
Take a photo of the rose connections and post here. We can tell you what is what.
Brilliant. Thanks.
I will but am up a ladder now (well not this second) & on with boarding so will do later to get back to you.
I will have to just push the rose up.for now (isolating the live / neutral in a block of course) and get a jnct box to follow.
Thanks again.
Hi Little, Dim here:
have attached a pic (not a lot of use tbh as it's all tucked in and behind really) but there for ref.
More useful, I hope, I have scribbled a diagram of it now and how I propose to resolve it using a wago box and connectors. So I'd be hugely grateful if you could mark my home work before I crack on. Thanks in advance.
[ElectriciansForums.net] Electrical ceiling rose move ahead of plasterer?
Looks like a twin red for the switch drop so should be obvious.
So guys (&gals) - as a double check, do the diagrams above look to be correct to crack on?
Also, I'll need some additional t&e to run along and down through the ceiling to the fitting. Is it 1.5m that I need please?
Reply to Electrical ceiling rose move ahead of plasterer? in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
