rmaynard
i went to price up a job with a colleague who is fq and registered, for a new install in an outside unit, it requires, socket, lighting and a shower/extract system plus a radial heater. As iv never done any design work i asked to do the design for it as a learning curve for me.
The location is a dog groomers inside a house, it already has a shower/extract system, sockets and lighting, so here goes for my plan and design and i need feedback.
the old groomers is to be decom and ripped out, The original shower is wired from the house cu in 10.0mm t+e fed from a 45a mcb on the rcd side, i was thinkiing of using this circuit and putting a new cu in the outbuilding, the quote comprises of, 2 ip rated strip lights and switch, 5 twin sso, one of which is above the shower so will be ip rated, shower and connection unit, extract system and fan isolator, radial heater and fcu, ip rated also. the new board will be a 6 or 8 way with rcbo's on sockets, shower, and radial heater.
Will upload design drawing later
Thoughts so far?
Rob
Thoughts so far?
Rob
