T
TailSpin
Hi All
Is there any regulations regarding motor isolation feed from inverters. As I have had quite a bite when checking a three phase motor which was locked off being feed from an inverter. The isolator was before the inverter and was left for a good five minutes to allow for discharge from inverter unit. It seems its would be better to put the isolator after the inverter ?
Motor was checked for dead before work commenced ,
Any thoughts ?
Regards
John
Any thoughts ?
Regards
John
