Electrical enclosure build | on ElectriciansForums
Discuss Electrical enclosure build in the UK Electrical Forum area at ElectriciansForums.net
Isle of Wight
Please can someone point me towards a beginners guide to wiring up simple enclosures.
I have built a small recirculating water system which consists of a pump, heater, flow switch, thermocouple and temperature controller. I would like to build the control box that will operate the system. Functions of the control box are as follows:
- Key switch for master on/off
- Pump on/off switch and light
- Heater on/off switch and light, coupled which flow switch to prevent element burnout in event of pump failure
- Eurotherm temperature controller to control heater power (via solid state relay) based on temperature setpoint monitors by K type thermocouple probe.
- Low flow alert light
- E-stop and reset button
I recognise that I am a beginner and will be having my work inspected by a qualified electrician, howevever I am very keen to learn electrical skills for future projects.
Any advice would be greatly appreciated.
I could be wrong, but you need to be aware that any non standard electrical enclosure will need to be subjected to rigorous testing and certification, by who and what organisation will be responsible I don't know, someone with more experience in this subject will be along later to advise, I'm sure.
Reply to Electrical enclosure build in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your input! I will speak to octopus and see what they say regarding a new tariff.
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
