Discuss Electrical fire in house in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Rough. Is that the main fuse for all 8 flats? It says 60A?
The burned plug and extension lead has nothing to do with the electrician.... that belongs the tenants. Maybe a loose fuse connection in the plugtop? (or the 13A fuse has been replaced with a nail)
The property needs an EICR before any tenants can move in. That should have picked up any faults and reported to landlord.
If this has been a rewire with sitting tenants, then they should have completed a test certificate and notified to LABC.
Is this 8 flats, or is it an HMO?
Hi this is the reportRough. Is that the main fuse for all 8 flats? It says 60A?
I knew it was bad please explain more please. I need to sue the landlordwho wrote those observations?
Johnny aged 5?
Well, as said before it is rough as fack
However, cowboy electrical probably installed that lot 30 years ago.
Fuse carrier has become weak with age and been arcing
Change burnt socket
Put enclosure round cable terminals feeding socket on floor, whilst your at it, screw it to the wall?
New fuse And holder or even better a fused isolator.
Back on supply, write report, suggest full eicr.
Off to next job by lunch time.
[automerge]1593590357[/automerge]
Just noticed the OP is listed as Tennant on profile.
My advice would be,
Write to landlord or agent asking for a copy of the electrical inspection report.
Consider your own actions,
it is not advisable to run heaters from extension leads, a heater is likely to use all the electricity the lead and adapter can handle safely without the added power of the other things plugged into it.
I am assuming that it is a heater or other powerful device that is running for long periods of time that is attached to the plug with burn marks.
It is also likely that the wall socket with burns around 1 pin has been caused by overloading it, by chance is that where the damaged extension lead plugs in?
Council issued hazard awareness cert and that’s it, it should of been prohibition order. Council have conspired with landlord, I mean can you tell me any hmo that has no fire doors but has a licence. He was running it for over 2 years without a licence then he gained one in 2017 and still no fire doors. I have been through everyone and I have solicitor, I just wanted more opinions from qualified electrical guys like yourself and the othersLook... you won’t get anywhere saying that “a bunch of electricians on an online forum said it was bad”
Try citizens advice, or a solicitor. They will know the rules regarding renting out a flat with no heating and the electrics the way it is.
Have you got a trusted friend or a social worker that could contact the landlord and find out what’s happening?
I find it difficult to see how the council can ignore this.
Johnny aged 5?
I believe this is fraudulent and the company he is using operate under two names I don’t like how this has been dealt with 8 flats £260 each flat per weekand those schedule of test results.... For a use of a word, Shocking, half the results are missing and incomplete
looks like he just copied and pasted the descriptions from the inspection schedule straight into the observations..... No locations, lacking any detailed descriptions; and the technical terminology he's used on the odd occasion he's bothered are something else...
All signed off by a Niceic approved contractor too... Is that really the standard they allow???
And he can afford skilled trades men he has handymen doing skilled work for penniesI believe this is fraudulent and the company he is using operate under two names I don’t like how this has been dealt with 8 flats £260 each flat per week
Hi what would you advisewho wrote those observations?
Johnny aged 5?
[automerge]1593607643[/automerge]
[automerge]1593608351[/automerge]
I’m not expecting you to be involved in the action I take, I just wanted a professional opinion on what I have posted. Been going on for years and it has to stop. I really appreciate your opinionsI can't / won't get involved with the whole suing the landlord thing you mentioned earlier.
I'm merely making observations on what i see as a shoddy report that's been issued. You could make a complaint about the standard of it to the NICEIC as that's the scheme they're members of, however, you may not get very far as it was the landlord who ordered and paid for the work.
Reply to Electrical fire in house in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
