E
eddyg2007
One of my friends has an electric hob that when you turn the temperature dial no matter what the setting is it always goes full heat, is there some sort of thermal fuse within the hob? im not too sure, thanks in advance
Discuss Electrical Hob Problem? in the Australia area at ElectriciansForums.net
sounds like a faulty regulating switch.Check if it is still under waranty.You will need serial no.make and model to source a replacement.
is that the dials with the temp setting that your talking about?
Reply to Electrical Hob Problem? in the Australia area at ElectriciansForums.net
