Electrical installation certificate help (EIC) | on ElectriciansForums
Discuss Electrical installation certificate help (EIC) in the Australia area at ElectriciansForums.net
flukey
Basildon, Essex
just been to price a job and they had an eic from feb 2006 for work completed in kitchen.
under comments on existing installation it says
  1. side extension and garage wiring not to BS7671 but it was left connected and still in service :eek:
  2. some switched live conductors in lighting circuits have no phase colour sleeving
i was taught that before issuing an eic any defects had to be addressed or left disconnected so my question is can you in fact list irregularities on eic or is it another job for me to sort out :confused:
As that part of the installation, i assume, was not touched there is no need to bring that up to date if you are just altering the kitchen.
So
1. Depends on what is not to bs7671?
2. Lack of sleeving is not unsafe, however, it would have taken less time to put some on than writing it down!
To be honest, it sounds like they have gone OTT as most sparks wouldnt even bother checking that kind of thing if they were not even working on it.
morning mate with out getting an eic from my van and checking eic is only for the work it lists ie kitch and comments only on exsisting installation. it really depends how serious any defects are you cant force people to have work done. sleaving to switch wires is going to be hard to convince them it needs doing. non complyance with 7671 is only a number4 on pir anyway.
thanks for the replies ;)
the extension and garage are in a real state and definitely wont be connecting them up to my nice new cu :eek:
the lighting only needed a bit of sleeve at switch and fitting so surely should have been done as a matter of course instead or recording it :confused:
i take it i will have to sleeve all switch drops now ive changed cu :confused:
hi guys iv gotta go and install a new cousumer unit to a three bed semi its all been rewired just needs the c/u, apparantly theres no power to the property the person ordering the work reckons tht the electricty company wont come and put fuse untill the installation had been certified dont knw how true this is realy, if i had to supply eic with no power would i hav to record tabulated values based on tt - tns - tncs earth systems witch ever one it is, for ze zs pfc etc the only other way i knw to work out R1 + R2 VALUES is calculated usein circuit lenth X m/ohms/per metre value i dont realy think i could supply a cert to be honest cos i cant even test rscs??? any help would be great thanks
tht was rcds by the way my typin is dyer sorrys guys lol
hi
connect the cu up and do all the dead testing, cont, ir, r1r2,etc make sure your bonds are connected when they come show them what you have done and the cirt and they should put the fuse in the main worry they have is ir tests because if there is a fault it could blow a fuse on their network
Indeed, you do not have to leave a finished cert for them to look at.
In most cases the person from the DNO that comes to look at the job, is not normally the person who does the connections.
Whenever i do installs i use a photocopied schedule of test results sheet from the EIC pad. This sheet i use on site.
You could also do this and show them if they ask.
Once the install in finished i write up the proper EIC with all the details and send it to the client.
Reply to Electrical installation certificate help (EIC) in the Australia area at ElectriciansForums.net
