Electrical Installation Licence | on ElectriciansForums
Discuss Electrical Installation Licence in the Australia area at ElectriciansForums.net
J
jowniofownio212
Hi Everyone
New to the forum. Not sure where to post this really but here goes:
I am looking to some day go self employed as a domestic electrician and dont know where to start with regards to licencing or courses. I have heard so many different things and its just confusing.
Currently, I work as a maintenance electrician and have the following certificates:
NVQ 3 Engineering Maintenance (Electrical)
17th Edition
HNC Electrical and electronic engineering
NVQ 2 Performing Engineering Operations (with units in electrical testing etc)
What is the easiest way I can become an electrician who can do odd jobs in peoples houses to start with and hopefully end up leaving my current job to continue this bigger scale?
I have been told I need to do NVQ 3 in electrical installaion to get my JIB licence? But this takes 2 years and I think I have done most the units involved.
Also, I have been told, all I need to legally do, is get the part p certificate and inspection and testing certificate and that is all I need?
Any advice?
Jon
not quite. with the quals. you already have, as long as you are competent, you can start right away. however, a good deal of domestic work falls under part p, and the easiest way to comply would be to join elecsa, napit, or niceic. you do not need a part p qualification as such. i suggest yo contact elecsa and napit and take it from there.
Agreed. Just out of interest, does anyone have an idea as to the MINIMUM quals needed to get through Part P approval?? I don't, by the way.
I don't want to dampen your enthusiasm but my Elecsa assessor said to me on Monday that he couldn't believe how many new people are joining schemes and he was wondering about "saturation".
Maybe you should google the competent persons scheme, enter your post code and see how "crowded" your area is at the moment.
At the moment just BS7671:2008, but this is about to change next year, requiring a NVQ LV3 as well as BS7671 (2011)
Thanks for the info mate. Just gave them a call at ELECSA and they said the following which I can sort of understand, correct me if I am wrong:
With the certificates I currently have, I can be assessed by ELECSA and be awarded the Part P and be able to carry out any work on houses without any more electrical courses needing to be done. This is classed as an electrical licence and I can work under it as long as I inform the buildings council?? of any work being done and needs renewing every year.
So if this is true, why is it JIB say I need to do NVQ3 in electrical installation then work for someone for 2 years doing testing and then apply for inspection and testing licence and then apply for full electricians licence?
Cheers
The JIB have different (more advanced requirements) criteria, and if you do search on here a lot of proper sparks look down on a DI, for the reasons of such low entry to the part Pee scams,
Being a DI does not make a sparky per se, as there are 5 Day wonder courses, and how can you become an Electrician in 5 days ?, and yes Iam a DI (though not a 5DW).
the JIB card is more often asked for on site work. not necessary for domestic. as regards elecsa, they are telling you rightly. you pay them the fee each year. you notify them for each job, and they, in turn, notify building control.
Ok
Thanks for advice. Is ELECSA the best to go through? Also, if I was to do it now and be assessed before the new rule where you need NVQ3, do I have the renew and repay every year or could I have years off? Or would that meen I would need re assessing and then need the NVQ 3?
Cheers
That's about the size of it, if you qualified now you would have to keep up your subs. or require Lv 3 the next time you applied
As to whether or not ELECSA (there are others) is the best or not depends on what you want to do, as if you are anticipating a lot of council etc. work, they may 'prefer' NICEIC, but the choice is yours at the end of the day.
In fairness, I think a lot of the 'blame' has to rest with the big 3 as far as DI and part P is concerned. Something needed to be done, fair enough, but NICEIC, The ECA and Napit were all too keen to see commercial opportunity rather than quality, jumped in way too quick and showed their hands too low. So it opened the door for all the 6 Week Wonder courses to be able to say 'do this, do that and you'll be a sparky'.
It's a bit like the PIR schemes that seem to be appearing, too. I have my 2391, it went into detailed theoretical and practical probing of my ability to test and examine. I'm perfectly entitled to inspect and test anyway under BS7671 (C&G 2382) without anything else.... so why would I want to spend another ÂŁ400 or so a year??
Hi
Thanks for all the advice. I am going to start looking into going down this route before January as the laws chage then suposably.
Does anyone know how true this chance of needing NVQ 3 in elec installation in 2012 is? As NICEIC have not heard anything about it and I would rather not rush? Who do I need to speek to to verify this for sure?
As there are a number of assessing bodies (NICEIC, ELECSA etc), who would you recomend going with? ELECSA charge less per year and less per house worked on??
Also, I will need insurance, who do you use?
Hi
What "Laws" are changing???
Reply to Electrical Installation Licence in the Australia area at ElectriciansForums.net
yeah I know it it is tough Brad, but keep going mate, chin up and all that, if you keep going something will go your way.
  • Solved
An NVQ is a vocational qualification and is based upon your work experience and what you put into your portfolio for your assessor to judge you...
