Electrical loading | on ElectriciansForums
Discuss Electrical loading in the Australia area at ElectriciansForums.net
A
Adebambo Adeoye
I m designing the electrical loading for an extension with an existing 4 bed hse. The loading of the existing hse is 1 x electric cooker. 3 sockets in every room and no electric shower. The protective device ( supplier) is 60Amps. The proposed extension is a 1 bed hse with an open plan kitchen. The loadings are 1 x electric cooker, 1 power shower, 3 x 1kw heaters total of 13 x 50w spot lights and 2 security lights.I propose to take the feed from the the existing property. Applying diversity,would 100Amps be enough to serve both properties. Just need a second opinion. many thanks
Be grateful you haven't got an 80A supply and 66A of continuous duty ground source heat pump!!!!!
Reply to Electrical loading in the Australia area at ElectriciansForums.net
