electrical lubricant | on ElectriciansForums
Discuss electrical lubricant in the Electrical Tools and Products area at ElectriciansForums.net
I have been using the product below on RCD spring coils.
The brand is 3-IN-ONE professional, high performance lubricant.
Drives out moisture
dramatically reduces friction and wear
Theres something you can import from the states which is for use on potentiometers on amps/guitars etc.... can't remember what it was called though as I discovered WD40 does the same job on pots.... wouldn't use that on an RCD though. Actually that was years ago, you can probably get it here now.
silicon sounds ok!! used to use that on my diving drysuit around the rubber neck seals..!!! :) makes shoving ones head through the hole a lot easier!!
Reply to electrical lubricant in the Electrical Tools and Products area at ElectriciansForums.net
My guess is that you'll need to have your existing re-jigged as you've probably got a separate consumer unit fed from the time clock side of your...
Thanks DefyG. I am thinking along those lines insofar as I will ask the electrician to build the DB/CU (plastic if he is OK with that)...
