Howdi all
Started on a new installation last week, changed all skts,light fittings.re wired ktchen and cooker circuit basically replaced almost everything!! today i changed the d/b all circuits with rcbos.all of my testing was spot on until i tested the Zs of each circuit!! My Ze was 0.13 and my R1 N R2 Values all looked good!!!However when a came to test for the Zs my results were all over the place 86.3 68.4 123 ohms!!!!!!!!!!!the multi meggar has just came back from callibration and i have had no problems in the past with this instument.Can this cause damage???? as my readings said that electrical noise was the cause!!! WHAT IS ELECTRICAL NOISE AND HOW DO I FIX THIS??? no data or low voltage cables in the house!!!!
many thanks
c.boy
many thanks
c.boy
