Been doing some mock papers but got stuck on few questions that i even tried to google but they dont specifically dum down the qs/answer. anyway here are the questions i need help on. (Not trying to get you guys to do my homework or anything just some questions i need help on which i can't find out) (some qs are answered though and u can skip some questions if u dont know or dont want to answer them) TY FOR UR HELP ITS MUCH APPRECIATED!
a fluorescent luminaire containts a capacitor for power factor correction.
State how the capacitor is connected in relation to the supply?
answer =
State the effect on the supply current if the capacitor is removed?
answer =
State the effect on the operation of the luminaire if the capacitor is removed?
answer =
Explain how load balancing may be achieved in a three phase four wire supply?
answer =
Explain the effect load balancing has on the neutral current?
answer =
Identify the type of motor used in a 110v a.c. drill?
answer i put = universal motor
State how the direction of the rotation maybe required for the motor above?
Explain what is meant by power factor correction?
answer = Power Factor Correction is the process of maximizing
the efficiency of an electrical system to deliver the most possible power as active power
answer =
answer =
answer =
answer =
answer =
