Electrical seperation help | on ElectriciansForums
Discuss Electrical seperation help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
rawlins1463
Hi
Please can someone help. This is probably a stupid question but i would appreciate some advice. I have recently started carrying out Electrical Condition Reports on waste water pumping stations. My question is are float switches which are supplied via a 24V transformer classed as being electrically seperated as there is no earth run to the float itself?
Electrical separation is identified by the double circles overlapping and for SELV either SELV or class III, however the transformer does not have to be separated as the float switch could be class II. You could do your IR tests for separation as if SELV and if it passes it is SELV, if it fails it may just be faulty SELV!
[ElectriciansForums.net] Electrical seperation help[ElectriciansForums.net] Electrical seperation help
Hi
There are no stupid questions, there are only questions you don't know the answers to. No one knows it all, although some profess that they do, but collectively we do know it all.
Cheers…………..Howard
Reply to Electrical seperation help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A suitable contactor can be used for safe isolation, but to be suitable it must be marked with the specific symbol for isolation and would have to...
M
Aqualisa electric shower, mains water entry point blanking plug Hello, Im looking for help in tracking down a replacement part for an Aqualisa...
Marty
M
