Electrical Test instrument | on ElectriciansForums
Discuss Electrical Test instrument in the Australia area at ElectriciansForums.net
E
elecypwn
Hey guys, iv just bought a alphatek multi easitest tester, i previously used the megger 1552, but anyway! with this new easi tester I am confused on how to perform a ZE reading, it has the settings " trip - lock " and Loop PSC, L-E and loop PSC L - N, What is the trip lock function it has no setting for ZE or ZS? could the Trip lock be what measures the ZE and ZS? cheers
A: RTFI
Q: No instructions, does the Easitest come with instructions?
A: Yes, usually, contact Metrel, they sell the manuals and theory of use of their instruments
Q: I need to use it now for a job, what should I do?
A: Zs/pfc = high current test (2 cycles at 10-25A). Do something interesting with the RCD
Q: Thanks for that but what about D-Lock?
A: D-Lock setting allows you to select a range of functions, from my older Eurotester, I can test various characteristics of RCDs, Test Zs at 15mA (not much good, as far as I'm concerned), Touch voltage etc.,
Q: Thanks very helpful - thank you once again.
A: That's alright any time :drool5:
Electrical test equipments are essential in our daily chores. It helps us in ensuring the safety of all our loved ones.The good thing is that you can now get them online too. Visit one of these websites and ensure the safety of your loved ones.
Trip lock is for doing a Zs on RCD/ RCBO protected circuits....most of these metrel testers have a line-line..and line-loop on them....line-line will be for doing a phase to neutral/phase loop which will also give you your PSCC.....your line-loop is for your Ze/Zs and will give you your PEFC.....you should be able to disable the trip lock feature for doing a Ze as it will be more accurate (high current loop)..........
Reply to Electrical Test instrument in the Australia area at ElectriciansForums.net
Hi, did you decide to upgrade your test meter? If so, how are you finding it?
