ENHANCED PROTECTION FOR MODERN POWER DEMANDS
Innovative, Protective & Efficient
Effective and easy to install solutions to safely manage the load between multiple electric showers or an electric shower & EV Charger. Protect your main incoming supply with GAROs Priority & Non-Priority Boards.
Don't forget all electriciansforums.net members can get an extra 5% off of all products on Electrical2Go!
DM us via the forum if you wish to join the discount club and start saving now!
HOW DO THEY WORK?
Garo Priority & Non-Priority Boards are designed to facilitate the use of multiple electric showers which are being supplied from a domestic single phase supply. These units can also operate in conjunction with other appliances, such as EV Chargers, Hot Tubs or Heat Pumps. These boards will disconnect a shower or other appliance, as required, in order to safely manage the total house load and protect the main fuse. All priority & non-priority products are fitted with type A RCBO/RCCB, which are suitable for electric showers up to 9.5KW & electric vehicle chargers with DC leakage protection.
STANDARD FEATURES
?Easy to install & wire
?Compact and well-designed unit
?Utilises silent contactors
?Fully compliant with 18th edition regulations
?Proven reliability & comprehensive warranties
?Fully backed & supported by GAROs technical experts
?Helpful instructions, wiring diagrams & video guides available
